4 ways HelloSign can help HR teams speed up onboarding
A slow, clunky onboarding experience can leave your new hires frustrated and less than likely to stick around long-term.
Unfortunately, this is because HR teams are often burdened with disjointed tools, excessive paperwork, and complex processes.
eSignature technology is the key to speeding up onboarding and providing a great experience for employers and employees.
Learn how eSignatures can help you create a simple, fully-integrated onboarding experience at your business.
Frequently asked questions
How can I speed up the onboarding process?
Use an open API that’s designed to fit seamlessly into your existing onboarding process.
Why should I use onboarding templates?
Customizable templates paired with a batch-send functionality means you can provide all the documentation new starters need to fill out.
What documents will new employees need?
Typically as part of the onboarding process employees can sign contracts, 1099s, W-2s, W-9s and NDAs.
How can my company stand out in the onboarding process?
Improve contract completion rates with mobile-friendly forms. Dropbox Forms is designed for mobile and pre-populates data into forms.
